010-12029-00 GARMIN CLASS B DRIVE UNIT LINEAR DRIVE FOR 48400 LB
Garmin is pleased to announce the new Class B Compact Drive Unit for the GHP 12 marine autopilot. The Class B Compact Drive Unit works with the GHP 12 Marine Autopilot System to control your sailboats steering system. This device is designed for use with sailboats with up to 48400 lbs of displacement.
Specifications
- Drive Unit Type: Integrated Hydraulic Linear
- Stroke Length: 10.0 (254mm)
- Maximum Thrust: 1610 lb (730 kg)
- Dimensions WxHxD (centered): 31.9 x 4.6 x 8.9 (810 x 120 x 225 mm)
- Supply Voltage: 10V to 30V (regulated to 12V by the ECU)
- Average Clutch Current at 12V: 1A
- Average Motor Current at 12V: 2-4A
- Operating Temperature: -15C to 50C
Price: 2577.73
