3119 BLUE SEA SMS SURFACE MOUNT SYSTEM PANEL ENCLOSURE - 120-240V AC-50A ELCI MAIN - 1 BLANK CIRCUIT POSITION
SMS Surface Mount System Panel Enclosure - 120/240V AC / 50A ELCI Main - 1 Blank Circuit PositionPanel enclosure for ELCI Main circuit breakers and other large frame devices. Meets ABYC E-11 when used with an ELCI Main circuit breaker and mounted within 10 feet of the shore power inlet.
Features:- Includes one 120/240V AC / 50A ELCI Main and one blank position
- Blank apertures for custom breaker loading
- Glass filled polycarbonate mounting box
- Clear cover allows easy view of circuit breaker status
- Overlapping cover for strength and increased gasket protection
- Oversized formed in place seamless PUR gasket
- Easily removable stainless steel hinge pin for unobstructed installation
- Stainless steel latch secures cover without penetrating the enclosure
- Blank circuit positions accommodate Carling Technologies A- and C- Series Flat Rocker and ELCI Main circuit breakers
- Stainless steel mounting hardware included
- Includes waterproof glands
- LED lights for back lighting and ON indication
Specifications:- Minimum Operating Temperature: -40 degrees C
- Maximum Operating Temperature: 85 degrees C
- Cover Screws and Hardware: 10-32 Stainless Steel
- Enclosure Size: 6.0 x 6.0 x 4.0 (152mm x 152mm x 102mm)
- Exterior Overall Dimensions: 7.6 x 7.4 x 4.7 (192mm x 188mm x 120mm)
- Mounting Hardware: 1/4 Diameter #12 (6 mm)
- Weight: 6.95lb (3.15 kg)
Product : BLUE SEA SMS SURFACE MOUNT SYSTEM PANEL ENCLOSURE
Manufacturer : BLUE SEA SYSTEMS
Manufacturer Part No : 3119
UPC : 632085031190
Price: 751.48
