6153 DAVIS VANTAGE PRO2 WIRELESS WITH 24-HOUR FAN ASPIRATED RADIATION SHIELD
Wireless Vantage Pro2 with 24-Hour Fan Aspirated Radiation ShieldProduct DescriptionA wireless weather station with a versatile sensor suite that combines our rain collector temperature and humidity sensors and anemometer into one package. You can customize your Vantage Pro2 by adding consoles or the special-purpose options.
First and only weather station in its class to use frequency hopping spread spectrum radio technology to transmit weather data wirelessly up to 1000 (300M).
Features- Large backlit 3.5 x 6 (9 x 15 cm) LCD screen
- Options available for UV/solar soil moisture short and long-range repeaters and much more
- Fast updates every 2.5 seconds
- Optional WeatherLink data logger and software offer additonal analyses in a variety of versions
- Wireless transmission from station to console up to 1000 (300M)
IncludesSolar powered Integrated Sensor Suite:
- Rain collector
- Temperature and humidity sensors enclosed in our solar-powered 24-hour fan-aspirated radiation shield (combines active and passive aspiration to minimize the effects of radiation)
- Anemometer with 40 (12M) anemometer cable
- Solar panel
- Vantage Pro2 console/receiver
- Power adapter for console
- Mounting hardware
Specifications- Electronic components are housed in a weather-resistant shelter
- Console may be powered using the included power adapter or with three C batteries (not included)
- Wireless range is up to 1000 (300M) outdoors line of sight. Typical range through walls under most conditions is 200 to 400 (60 to 120M)
- Add wireless repeaters for distances up to 1.7 miles (2.7 km)
Product : DAVIS VANTAGE PRO-2 WIRELESS WITH RADIATION
Price: 952.44
