940800250 MOTORGUIDE XI5 WIRELESS TROLLING MOTOR - FRESHWATER - SONAR-GPS - 105LB-54-36V
Xi5 Wireless Trolling Motor w/Wireless Pedal & Pinpoint GPS RemoteThe Xi5 is designed to exceed the expectations of todays discriminating customer. Its engineered to be reliable every day - and durable over the long haul. Unlike the competition the Xi5 includes wireless capability right out of the box anglers can command precise motor and steering control from anywhere on the boat. A wireless foot pedal is standard with freshwater models. Plus weve made it stealthy quiet and silky smooth. And youll also see thoughtful details that make it safe and easy to use.
Key AdvantagesStatus Indicators at a GlanceThe Xi5 uses LED lights in the controller so anglers can quickly check the status of four key functions in any light conditions. The battery power indicator uses different colored lights to show three levels of battery life in real time.
Wireless Pedal for Precise ControlOur wireless pedal provides outstanding motor control from anywhere on the boat. The intuitive pro-style heel-toe operation controls steering thats extremely quiet precise and 50% faster than the competition. Digital variable speed control enables exceptional low-speed trolling capability and longer run time.
Next-Gen Digital TechnologyOur wireless pedal provides outstanding motor control from anywhere on the boat. Our new Digital technology features durable cooler-running power electronics that are 50% more efficient. They also capture and store energy that is typically lost as heat. This improved efficiency means longer run time and fewer battery charges. Digital speed control delivers power smoothly and incrementally at the precise level needed by the operator.
Low-Profile MountAn improved low-profile mount is all about form and function. The base uses anodized aluminum to prevent corrosion. The ha
Price: 2536.99
