The Barracuda B12 delivers the killer blow to its rivals with its class leading 4500 fixture lumensthe patented coaxial collimator with maximum penetration into the ocean creating breathtaking illumination. The compact low profile design makes the Barracuda B12 the perfect choice for all types of boats and is suitable for transom and side mounting on all hull types. Incredibly simple to install just one small cable entry hole2 wires to connect and 3 mounting screws. Reverse polarity protection with in built driver technology and active thermal control Guard X protective coating prevents marine growth.
Features
