BLUEFIN LED S20-TH-G302 STINGRAY S20 THRU-HULL UNDERWATER LED LIGHT - EMERALD GREEN
The Stingray S20 Underwater Light carries a deadly sting in its tail this Thru Hull light offers formidable power without compromise suitable for Transom mounting on all hull types.
Installation could not be simpler thanks to our built-in driver technology just one small 1 in. hole for the stem and two wires to connect. Reverse polarity protection with active thermal control Guard X protective coating prevents marine growth.
Specification- Suitable transom mounting.
- Surface mount requires 25 mm/1 in. cable entry hole.
- Recommended for boats upto 25 m/80 ft.
- Fixture Lumens 9000.
- Typical LED life expectancy 50000 + hours.
- Voltage 24V Power Draw 7.5A.
- Over voltagecurrentreverse polarityactive thermal protection.
- Fixture profile 30.75 mm/1.2 in.
- Fixture diameter 140 mm/5.5 in.
- Fixture Length 200 mm/7.87 in.
- Lens - optical grade 8 mm. Borosilicate glass 65 Degree beam angle.
- Body AB2 Bronze throughout.
- Item Weight - 5.94 lbs.
- Thru Hull Underwater Light.
- Emerald Green.
Price: 1636.83
