FISH SCOUT UNDERWATER CAMERA SYSTEM - DOUBLE VISION WITHOUT SONAR
Fish Scout Underwater Camera System - Double Vision without SonarManufacture ID: FSDV01
Fish Scout Double Vision without sonar makes it easy for current Vexilar owner’s to upgrade to a combo camera/sonar system into one awesome pack. The Fish Scout Double Vision system starts with a great 16:9 wide-screen color monitor 80 foot of marked cable a color/black and white camera system that automatically shifts from color to black and white mode in low light conditions. Your Fish Scout Double Vision system has its own carrying case with two options for over- hole suspension arms and even a battery status indicator. This system comes with a 9 amp hour 12 volt battery and a 1 amp hour battery charger. Each system comes with BOTH power cords to power any Vexilar FL Flasher series the FL8 FL18 FL12 FL20 and FL22hd Flashers. Simply remove your Vexilar sonar from your current pack and plug it in and you are ready to go fishing.
Features:
- 7 16:9 widescreen LCD color monitor
- Operating range of -22 Degrees F to 150 Degrees F
- Monitor resolution: 480X3 (RGB)X234
- Video Out option
- Sony Super HAD CCD color/black and white camera
- 90 degree viewing angle
- Cable Length 80 feet
Specifications:
- 420 lines of resolution
- Lux: Color .51 B&W - .05
Price: 741.52
