ICE EATER P750-25-115V POWERHOUSE 3 - 4HP ICE EATER WITH 25 FOOT POWER CORD
3/4 H.P. energy efficient high quality motor with 36 pounds thrust 4.7 amps 115 volt one phase 60/50 cycle 25 foot quick change power cord Two 25 foot x 3/8 hollow braided mooring lines with shackles Dimensions of shipping box 14 1/2 x 14 1/2 x 16 1/8 Weight 45 pounds Motor housing is constructed of 16 gauge 304 stainless steel and bronze endbell for corrosion free operation in fresh or salt water; Motor exceeds NEMA specifications and is UL and CSA compliant and C.E. certified Motor shaft is 316 stainless steel the best material for salt water application Permanent split capacitor ensures quick high torque and smooth operation while producing the highest efficiency of a single phase induction motor; Motor and capacitor are matched for ultimate performance Internal heavy duty hard faced mechanical seal with stainless components immersed in dielectric lubricating fluid; Additional double lip shaft seal for extra protection Stator motor windings have double impregnation of baked insulating varnish Two heavy duty ball bearings provide support for the rotor while being cooled with dielectric type oil Sacrificial custom designed zinc is provided for conditions where electrolysis may be present Propeller is custom designed for maximum thrust and performance; Propeller screws on shaft for easy removal and replacement Twenty-five feet of 16/3 water and oil resistant cord with three prong molded plug is standard; Additional length cord available: 50 and 100 feet Heavy duty PVC custom brackets that attach motor to shroud; All stainless bolts and locking aircraft nuts are used Performance certified tested at our facility for proper output and leaks before shipment Best three-year limited warranty in the marketplace Comes complete just open the box remove and install Optional thermostat custom design turns Ice Eater on when needed. Ideal for unattended applicationProduct : POWERHOUSE ICE EATER 3/4 HP 115V W/ 25 CORD Manu
Price: 891.89
